LTSpice "Time step too small" error
Discussion in 'The Projects Forum' started by Hekky, Jun 14, 2015.
  1. Hekky
    Jun 14, 2015
    I'm working on an audio power amplifier. I recreated the schematic from the internet in LTSpice and now I'm getting error: "Analysis: Time step too small; time=1e-006;timestep=1.25e-019;trouble with bzx84c15l-instance d1". This is the first time I'm using this program and I have no idea how to fix this.
    I also have a second question. I was getting error: "Voltage source V2 and voltage source V3 are paralleled making an over-definied circuit matrix. You will need to correct the circuit or add some series resistance". I added 10Meg, because I read somewhere that the resistance here should be this big. Is this a good solution?
    I attach schematics from Eagle, LTSpice and the original one.
      File size:
      49.6 KB
      15
      File size:
      58.1 KB
      19
      File size:
      122.6 KB
      17
  2. WBahn
    Mar 31, 2012
    18,087
    4,917
    The "time step too small" error normally comes about because you have something that is trying to change too fast, possibly while trying to solve for the initial operating point for the simulation. I can't tell which device D1 is because you aren't consistent in your reference designations between these schematics and I don't feel like guessing.
    You power supplies are not hooked up correctly. The should be between the return side of the speaker and the top/bottom rails. As you have it, you are trying to power your amplifier THROUGH the supply bypass capacitors!
  3. Alec_t
    Sep 17, 2013
    5,971
    1,135
    That's far too big for the resistance of a voltage source. Try 1 Ohm (or less).
  4. WBahn
    Mar 31, 2012
    18,087
    4,917
    If he corrects the schematic, he won't need any resistor because the two supplies won't be in parallel. If he just changes the resistor to some small value, he will simply have a lot of current in that resistor without having fixed the actual problem.
  5. Hekky
    Jun 14, 2015
    Thanks,
    Can you show me how the schematic should look like after correction? The problematic diode is marked as D1 on LTSpice schematic and as D6 on original.
  6. WBahn
    Mar 31, 2012
    18,087
    4,917
    D6 is in the bridge rectifier in the original schematic. Your LTSpice schematic doesn't have the bridge rectifier at all. D1 in your LTSpice schematic is a zener diode over near Q2. Ah, I see that it is also marked D6. That schematic has two D5 and two D6 designated parts.
    Correct the power supply problem and see if that makes the time-step problem go away. If not, we can deal with it then.
  7. Hekky
    Jun 14, 2015
    Can you show me how exactly can I correct this? I'm not sure if I understand the solution.
  8. WBahn
    Mar 31, 2012
    18,087
    4,917
    How, exactly, is CON2 supposed to be wired up to the rest of the world? I'm particularly interested in how the center pin is related to the AC power that is provided on the other two pins.
  9. ronv
    Nov 12, 2008
    3,398
    1,455
    Yes, the supply I think. Try grounding the right side of R37 in the spice schematic. It might help if you posted the .asc file.
  10. Alec_t
    Sep 17, 2013
    5,971
    1,135
    Like this:-
    ebeowulf17 likes this.
  11. ebeowulf17
    Aug 12, 2014
    682
    79
    For starters, I agree with Alec's recommendation above.
    Also, I got the exact same error about a week ago and simply adding a ground through a high-value resistor (500M) to my isolated high voltage side solved the problem. Here are a couple links that might explain better than I can:
    http://microcontrollers.2385.n7.nabble.com/LTSpice-grounds-problem-td44955.html
    http://www.electronicspoint.com/thr...-with-floating-nodes-on-using-relaysw.123096/
  12. Bordodynov
    May 20, 2015
    671
    194
    Do how on my picture: Supl.png
  13. Hekky
    Jun 14, 2015
    Thank you, I changed my schematic to this and now there are no errors.
    But, in the original schematic there were BD911/912, BC550, 2SK1530/2SJ201 transistors and 1N4007 diode - I'm not sure which elements in LTSpice can substitute them. I attach my .asc model.
    There was supposed to be 300W on the load (8ohm) with 1.5V input voltage (according to the datasheet of this schematic).
  14. Bordodynov
    May 20, 2015
    671
    194
    Look my collection of models. Though she is satisfied old, but contains the elements mentioned by you. More update version you can find in LTspice Yahoo Group.
    http://ltwiki.org/files/Standard.zip
