ltspice switch mode volt reg
Discussion in 'Homework Help' started by Random3s, Dec 18, 2014.
  1. Random3s
    Jul 30, 2014
    38
    Hi all,
    I am trying to design a SMPS using ltspice, this is part of a course I am currently doing.
    I have attempted to build a switch mode voltage regulator using an LT1070, with component values taken from a course textbook, attached is my circuit in LTspice.
    I am not sure how to represent a load in ltspice. The output should be 12v 1A (5v input), but I am not getting this and I suspect its because of the values of load resistors I have used.
    In the diagram I have represented the load with R4, 1k....
    Id appreciate any pointers to set me on the right track here..
      File size:
      158.8 KB
      79
  2. MikeML
    Oct 2, 2009
    5,450
    1,066
    Lets see, you can "design" a SMPS, but you cant figure out Ohms Law. R = E/I = 12/1 = ?
  3. Random3s
    Jul 30, 2014
    38
    :D
    I should have mentioned that by adding a 12 ohm resistor, the circuit failed to function correctly. Theres something missing or incorrect from the circuit.... I originally thought it was the choice of load resistance. ltspice is new to me, is there anything else you can see which would stop the circuit responding correctly?
  4. MikeML
    Oct 2, 2009
    5,450
    1,066
    You copied Linear Technology's test fixture (recommended circuit) for the LT1070 incorrectly. All the component values are the same (except for the Shottky diode, which is critical), but the connections are not.
    Use their simulation directive, too.
  5. Random3s
    Jul 30, 2014
    38
    input wasn't connected into the circuit correctly. Thanks Mike, great motivation. :)
  6. Random3s
    Jul 30, 2014
    38
    Actually I copied the text book circuit..... who apparently copied the test fixture circuit incorrectly.
    But good to know there is a test fixture for components.
  7. MikeML
    Oct 2, 2009
    5,450
    1,066
    All of the LTC IC parts they supply Spice models for are built into the LTSpice simulator. Each has a example test circuit. For example, your LT1070: Here is how you open its "test fixture":
    You first push into the LTC-supplied PowerProducts library. Then you select LT1070. Then you click on Open this macromodel's test fixture. The test circuit opens. Same thing for OpAmps, etc.
  8. Aaron Hinton
    Aug 13, 2015
    I have been trying to find suitable values for R1 and R2 in the circuit you have been discussing above to get an output of 9V/1.5 A.
    I'm really struggling. Can any one give me some help or guidance?
    Thanks =)
  9. Jony130
    Feb 17, 2009
    3,990
    1,115
    check this file
    R1 = 10kΩ ; R2 = 1.6kΩ
  10. Aaron Hinton
    Aug 13, 2015
    Hello Jony,
    Thanks for your very prompt reply. Ive taken a look at the file you sent. It seems that the circuit is stabilizing at 9V but the Amps are still not 1.5A. Do you know what is needed to make the circuit 9V/ 1.5A?
    Cheers =)
  11. Aaron Hinton
    Aug 13, 2015
    Ive just changed the load resistor to 6 ohmhs and it seems to be giving the right current now. Thanks for you help its much appreciated.
