LTSpice - simulating the switching of an inductor
Discussion in 'General Electronics Chat' started by atferrari, Jan 18, 2015.
  1. atferrari
    Thread Starter AAC Fanatic!
    Jan 6, 2004
    2,666
    784
    Using LTSpice to simulate the switching of an inductor as per attached .asc file.
    I understand that the emitter current (Q2), at the moment it is turned on, should be positive starting from 0 mA.
    LTSpice insists in showing a negative current which contradicts the sense of the one through L2, which is positive, starting from 0.
    BTW, current through D2 is consistent with that of L2.
    At lost here...
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Capacitive coupling from the base to the emitter of a fast rising signal. Try changing your rise/fall times of V2 to 1uS instead of 10nS
  3. Jony130
    Feb 17, 2009
    3,991
    1,116
    If current is leaving the node simulation gives this current a minus sign. Probe a collector current.
    atferrari likes this.
  4. atferrari
    Jan 6, 2004
    2,666
    784
    No changes SW even with higher rise/fall times. What makes me doubt is that collector current IS positive but emitter's is not. :( Electrons, where do they go? :oops:
  5. Jony130
    Feb 17, 2009
    3,991
    1,116
    Simply, the emitter current is leaving the node (emitter is sourcing the current). And all "sourcing" currents are negative in LTspice.
  6. atferrari
    Jan 6, 2004
    2,666
    784
    Gracias Jony.
    I was trying to understand how an inductor behaves and suddenly this!
  7. Jony130
    Feb 17, 2009
    3,991
    1,116
  8. atferrari
    Jan 6, 2004
    2,666
    784
    Thanks Jony. Finished the reading. I think I got the basics clear now.
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You might also head over to Ronald Dekker's site: http://dos4ever.com/
    and check out the "Flyback Converters for Dummies" section: http://dos4ever.com/flyback/flyback.html
    It's a very useful introduction to inductors; I've sent lots and lots of folks there to read up on them. The bonus is, there's a project that relates exactly to what you're interested in doing.
  10. killivolt
    Jan 10, 2010
    432
    351
    Hey Sgt. Got any models of TIP32c and TL431
  11. Jony130
    Feb 17, 2009
    3,991
    1,116
  12. atferrari
    Jan 6, 2004
    2,666
    784
    Thanks for sharing that Sarge.
    SgtWookie likes this.
  13. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    There is a model of the TL431 in LTSpice's Misc folder.
    I believe I'd retrieved a TIP32 model from ONSemi's (formerly Motorola) site:
    http://www.onsemi.com/PowerSolutions/supportDoc.do?type=models
    Might as well get the TIP31 models while you're at it so you'll have the complements. ;)
    killivolt likes this.
  14. killivolt
    Jan 10, 2010
    432
    351
    Thanks, Sgt.
    I like your signature; my thoughts exactly.
    Best wishes;
    kv
