LTSpice regulation
Discussion in 'General Electronics Chat' started by feynman82, Oct 8, 2012.
  1. feynman82
    Oct 8, 2012
    I'm very new to LTSpice and am trying to implement an output voltage regulated Buck converter through the use of the 'bv' behavioral voltage source.
    The converter is being driven by a PWM generated waveform which I have generated using a triangle wave (using the PULSE option of the voltage source) and am using a bv source in the main circuit to test this against a threshold value to feed an ideal switch. I'm now stuck as to how I go about modifying the duty factor for the switching voltage to maintain a constant output of 10V, using another bv source?
    Any ideas?
    Regards,
    J.
  2. crutschow
    Mar 14, 2008
    13,471
    3,359
    Post the circuit diagram.
  3. feynman82
    Oct 8, 2012
    Thanks, attached.
  4. feynman82
    Oct 8, 2012
    Sorry, attached as png image as well. Thanks!
