LTSpice "R" Simulation
Prabu1004
Joined Apr 17, 2013
Simulated transient analysis of a simple Resistor divider network with the below settings using LTSpice. From simulation, observe that Voltage & Current are 180 deg out of phase. Actual relationship is in-phase for R network between Voltage & current.
R1=1K, R2=1K
Vin = 1V peak to peak, 60Hz & 10V offset
Attached herewith the Simulation result & R network.
Green --> Input Voltage
Red --> Current drawn from Source Vin
Blue --> Output Voltage.
Regards,
Prabu.
34,431
The reason is the direction that LTspice assumes for positive current. If you hold the cursor over the resistor you will observe that the current arrow is pointing to the left. This means that current through R_1 will plot as negative for current going from left to right, as is the case for your circuit. If you draw the circuit as a mirror image, you will get a positive current for positive voltage.
