Ltspice question
Discussion in 'General Electronics Chat' started by Aleph(0), Nov 18, 2015.
  1. Aleph(0)
    Mar 14, 2015
    356
    339
    So I post this in its own thread so not like hijacking HP's ltspice thread
    For series circuit of 25kv 30khz sinewave generator + 1nf cap + 10k resistor + ground
    I manually calculate and double check
    So Z≅10K+5305.2i rectangular form.
    So Z≅11.32k∠0.488 polar form (Sorry if ugly This my first time for symbol bar)
    So current should≅2.2085 amps but when I simulate with ltspice no matter how much I F#(% with cursor and magnifier I can't read more than 2.1872A:(
    I'm sorry about saying like crybaby on HPs thread:( I adopt her attitude now cuz I want to just learn so I bite back on negativity and just pay attention:) Tnx for help:)!
  2. crutschow
    Mar 14, 2008
    13,462
    3,353
    Can you post your .asc file?
    Aleph(0) likes this.
  3. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,831
    1,305
    Indeed! -- @Aleph(0) --- Far be it from me to 'kibitz' - howbeit you really need to get on your ISPs backside in regards to easing your "VPN" restrictions! - Images really are worth much more than one thousand words and that goes double on these international fora... (OBTW - if 'flash' is indeed the problem, be advised that upload is possible without it -- though I ignore the details:oops:)
    Anyway... Give me a few minutes to construct a simulation based upon your text - While I'm honored that you asked me to have a look - you should know that I'm a knuckle-dragging neanderthal when it comes to Spice:oops::oops::oops: --- Back in a trice!:)
    Best regards
    HP
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
    Set maximum time step at 10ns
  5. Hypatia's Protege
    Mar 1, 2015
    2,831
    1,305
    Aleph, what can I say??? -- I see your point:rolleyes: (assuming the below pictured simulation is consistent with your circuit) -- FWIW your math looks good too...
    Best regards
    HP
  6. Hypatia's Protege
    Mar 1, 2015
    2,831
    1,305
    @Jony130 --- Sorry, I missed your response in the crosspost:oops:
    @Aleph(0) --- Get it? The simulator's default settings had it stepping too 'coarsely' and, hence, 'over' the 'crest' as it were... You may set the step interval in the simulation command dialogue...
    FWIW here are my results with my simulation of your (assumed) circuit... --- Although I didn't get fully to the calculated value - I think you get the point!:)
  7. Hypatia's Protege
    Mar 1, 2015
    2,831
    1,305
    Addendum:
    @Aleph(0) Just a friendly heads up:)
    --Electronics application of "phasor notation" (and its ilk) prefers 'j' to 'i' for representation of the imaginary unit (Perhaps to avoid confusion with current - "I":confused:)
    --While I fully concur with your preference for radians -- Convention prefers degrees (outside of mathematical and abstract scientific settings) --- Yes! Yes! I know!!! It's counterintutive and downright bizarre!!!:rolleyes::rolleyes::rolleyes: --- Still, ease of communication can be nice too... Perhaps we're all masochists at heart?:D:D:D
    Best regards
    HP
    PS -- Now don't you become one of those folks who can't handle constructive criticism "when it happens":p:D:D:D
  8. Bordodynov
    May 20, 2015
    669
    194
    See
  9. Aleph(0)
    Mar 14, 2015
    356
    339
    HP it price I pay for free isp perk from VGH foundation but is ok cuz you guessed circuit right:)! HP I know all about custom of j for i and about degrees but I say right and wrong aren't a popularity contest! So like science is the body but math is immortal soul plus all that raises humans above other animal life so that's where I'm comfortable:cool:
    Tnx Jony! More rapid sample time did trick:)!
    Bordodynov I think you are showing me way to exactly measure maximum excursion but I can't totally understand:oops: Plz say more:) Tnx to everybody:)!
  10. Hypatia's Protege
    Mar 1, 2015
    2,831
    1,305
    Jarring though it may be - utilitarian convention isn't entirely without merit!!!:cool::cool::cool:
  11. Bordodynov
    May 20, 2015
    669
    194
    To calculate the amplitude of the current I used one hundredth period of oscillation.
    This is due to the fact that the established processes is obtained immediately.
    I showed with the new scheme the first period, and for the hundredth time.
    I also made a Fourier analysis.
  12. Aleph(0)
    Mar 14, 2015
    356
    339
    Tnx Bordodynov:)! Could you plz upload the .asc for that so I can explore the ways of it without having to already know how to enter it all?
  13. Bordodynov
    May 20, 2015
    669
    194
    Hypatia's Protege and Aleph(0) like this.
  14. Aleph(0)
    Mar 14, 2015
    356
    339
    Thanks:)!
