LTspice question: What happened to the ammerter?
Discussion in 'Electronics Resources' started by DickCappels, Aug 22, 2016.
  1. DickCappels
    Thread Starter Moderator
    Aug 21, 2008
    2,768
    669
    After running a simulation in LTspcie I tried to measure the current thought some resistors, but the ammeter did not appear as the cursor hovered over the parts. "Ok, no problem" I thought, and reinstalled LTspice. Voilà! The ammeter was back. I shut down the computer.
    Upon restarting the computer and running a simulation the ammeter failed to appear. Is there a secret setting that I have been missing all these years?
  2. ericgibbs
    Jan 29, 2010
    2,590
    390
    hi Dick,
    I have never observed that problem.
    Could you post your 'asc' file and I will see if I can duplicate the problem.
    E
    EDIT:
    Try holding down the ALT key, while clicking on the component or wire.
  3. DickCappels
    Aug 21, 2008
    2,768
    669
    There is the file. The ammeter appears when I run it on the Mac OS but not on XP.
    Holding down the ALT key did not help.
  4. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,845
    1,314
    FWIW I've occasionally experienced the described difficulty while running LtSpice under XP Pro but not on Win7 Ultimate -- On a possibly related note, I have been unable to stipulate ammeter 'polarity' following installation of LtSpice upates Ca. 1 year ago:confused:...
    Best regards
    HP
  5. Alec_t
    Sep 17, 2013
    5,971
    1,135
    Cursor becomes ammeter/thermometer icon ok here with your .asc file. Win10, latest LTS.
  6. ericgibbs
    Jan 29, 2010
    2,590
    390
    Same here, works OK.
    Using Win XP Pro.
    Latest LTS.
  7. DickCappels
    Aug 21, 2008
    2,768
    669
    This is embarrassing as well as dumb. I introduced the problem when trying to get the program to stop leaving all of the intermediate files. I had unchecked "Save Device Currents" in the Save Options tab of the Control Panel. I was sure there was some switch, but didn't recognize it until all of you reported no problem.
    Yes, I found the correct place to delete the intermediate files too.
    Thank you for your feedback and help.
  8. Hypatia's Protege
    Mar 1, 2015
    2,845
    1,314
    I dunno - It has been my experience that the described difficulty (along with several other 'simulation time' annoyances) occur randomly under XP (as of installation of an LtSpice update last autumn) Note that I have never encountered said difficulty under Win7 --- FWIW I put it down to the commonplace (if indolent) practice by developers of ignoring 'orphaned' OSes despite continued widespread use of same:rolleyes:
    Well hey! Pleased it's working for you!:cool:
    Best regards
    HP:)
