LTSPICE Question for MOSFET
Discussion in 'Homework Help' started by KaiL, Aug 16, 2016.
  1. KaiL
    Aug 30, 2014
    61
    Addition information
    • Maximum voltage for both Vds and Vgs are 3V.
    This is my circuit.
    In LTSPICE , I set 3V for both Vds and Vgs .
    I am also required to extract the threshold voltage. In order for me to find the threshold voltage , am i correct to say that I set Vbs = 0 in LTSPICE?
    Then once I am done for the first part I set Vbs = -0.5V to find the threshold voltage of NMOS.
  2. crutschow
    Mar 14, 2008
    13,479
    3,366
    To determine the threshold voltage you can set Vgs to generate a ramp voltage and then observe Ids to determine when the specified threshold current is reached.
  3. KaiL
    Aug 30, 2014
    61
    Thank you very much for your reply.
    Before I generate the ramp voltage to find the threshold voltage , I set the Vbs = 0 then observe IDs to find threshold voltage.
    Thereafter I have found the threshold voltage for Vbs=0 , I set Vbs = -0.5 and generate the ramp voltage again to find the threshold voltage when Vbs=-0.5. am I correct?
  4. crutschow
    Mar 14, 2008
    13,479
    3,366
    That sounds correct.
  5. KaiL
    Aug 30, 2014
    61
    Ok thank you very much
  6. Bordodynov
    May 20, 2015
    670
    194
    alternative method. Controlled source replaces the operational amplifier.
