I am trying to use a model of LM5111 mosfet driver obtained from TI, and I found a serious problem with its implementation. When Vee sits on ground of the circuit everything is fine, but when I try to drive a high side switch and shift if above 0V it stops working (see attached circuit). Could someone help me find the problem in the subckt definition and help me get it fixed?
