LTSpice MOSFET model
Discussion in 'Homework Help' started by domino89, Apr 28, 2014.
  1. domino89
    Sep 24, 2013
    22
    I have this kind of MOSFET model:
    .model nmos. NMOS
    + LEVEL=1
    + LMIN=0.5e-6 LMAX=50e-6 WMIN=0.9e-6 WMAX=1
    + VTO=0.7 GAMMA=0.45 PHI=0.9
    + NSUB=9e14 LD=0.08e-6 UO=350 LAMBDA=0.1
    + TOX=9e-9 PB=0.9 CJ=0.56e-3 CJSW=0.35e-11
    + MJ=0.45 MJSW=0.2 CGDO=0.4e-9 JS=1.0e-8
    .model pmos. PMOS
    + LEVEL=1
    + VTO=-0.8 GAMMA=0.4 PHI=0.8
    + NSUB=5e14 LD=0.09e-6 UO=100 LAMBDA=0.2
    + TOX=9e-9 PB=0.9 CJ=0.94e-3 CJSW=0.32e-11
    + MJ=0.5 MJSW=0.3 CGDO=0.3e-9 JS=0.5e-8
    And i want to use it in LTspice but it doesnt work... Do i need to edit it?
  2. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Yes. Paste the text onto your schematic as a spice Directive, then correct 'nmos. NMOS' and 'pmos. PMOS' to 'nmos NMOS' and 'pmos PMOS' respectively.
  3. domino89
    Sep 24, 2013
    22
    I just did it... Same as before. But arent 'nmos.' and 'pmos.' just the transistor model names? So changing it to: without a dot wont change anything? Or this model just doesn't work... I was tasting it on simple inverter and i got output signal same as input.
  4. crutschow
    Mar 14, 2008
    13,479
    3,366
    My LTspice MOS library (LTC\LTspiceIV\lib\cmp\standard.mos) has the models in this form for nchannel and pchannel devices:
    .model Si7386DP VDMOS(Rg=1.7 Vto=2.57 Rd=3.5m Rs=1.4m Kp=58 Lambda=.014 Cgdmax=.67n Cgdmin=.1n Cgs=1.56n Cjo=1.56n Rb=6m Is=2.3p N=1.075 tt=25n mfg=Siliconix Vds=30 Ron=7m Qg=11.5n)
    .model Si7409DN VDMOS(pchan Rg=3 Vto=-0.8 Rd=7.6m Rs=5.7m Rb=10m Kp=72 Cgdmax=1n Cgdmin=.25n Cgs=1.7n Cjo=.5n Is=50p mfg=Siliconix Vds=-30 Ron=19m Qg=25n)
    so you might try modifying your model to correspond. Note that the pchannel device have "pchan" as the first word in parenthesis but the nchannel device has no indicator (apparently nchannel is assumed if "pchan" is not there).
  5. Alec_t
    Sep 17, 2013
    5,968
    1,135
    It works just fine for me.
  6. domino89
    Sep 24, 2013
    22
    Wierd... What could i make wrong if its working for u :/
  7. crutschow
    Mar 14, 2008
    13,479
    3,366
    I'd look for a typo.
  8. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Are you sure you have the model text as a Directive (a 'dot command'); not a Comment ?
  9. domino89
    Sep 24, 2013
    22
    It works ! My mistake was that I wasnt declaring transistor sizeing...
  10. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Good that it works for you. I didn't need to declare transistor size though.
