Hi everyone,
Just to confirm, in LTspice when simulating and plotting current does the following sound reasonable?
If I am plotting the current through a FET called "M1", the following default trace data would be:
Id[M1] --> MOSFET drain-source current?
Ig[M1] --> MOSFET gate current?
Is[M1] --> MOFSET substrate current? Would this be the same as the body diode?
Thank you,
Obanion
Thank you,
Obanion
