Is it possible to make a simulation with step load cap? For example 1pF, 2pF, 3pF ... 10pF?
D Thread Starter domino89 Joined Sep 24, 2013 22 May 8, 2014 #1 Is it possible to make a simulation with step load cap? For example 1pF, 2pF, 3pF ... 10pF?
V Veracohr Joined Jan 3, 2011 772 May 8, 2014 #2 Yes. Give the cap a value of something like {C1} (including the curly braces), then insert a directive: .step param C1 1E-12 10E-12 1E-12 That should step it from 1pF to 10pF in 1pF increments.
V Veracohr Joined Jan 3, 2011 772 May 8, 2014 #3 Or maybe instead of 1E-12 you can use 1p. I'm not sure, I can't test it at the moment.
D Thread Starter domino89 Joined Sep 24, 2013 22 May 8, 2014 #5 Ohh ty... I was declaring cap name without braces and didint know how to make it work
