The attached image shows the response of a diode through a temperature sweep. It appears to be linear.
Is there a way to plot the deviation of the response against a straight line of approximate the same slope? i.e. just to show the deviation or non-linearity?
I know I might be able to get that by using waveform arithmetic but I just can't seem to be able to use 'temp' as the x-axis variable in the calculation to get the deviation.
