me workin on my project in LTspice.....is there any method to find the resistance between 2 nodes directly in LTspice....
It may not be easy or straightforward but you can write an expression for the voltage difference between two nodes divided by the sum of the currents in each branch. Why you would want to do this is quite beyond me and seems excessively error prone.me workin on my project in LTspice.....is there any method to find the resistance between 2 nodes directly in LTspice....
That's basically the right idea, but there's an easier way.It may not be easy or straightforward but you can write an expression for the voltage difference between two nodes divided by the sum of the currents in each branch. Why you would want to do this is quite beyond me and seems excessively error prone.
by Jake Hertz
by Aaron Carman
by Jake Hertz
by Duane Benson
