I've built an inverter with current measurement using current transducers (CT) in each leg.
Simulation works fine except CT part.
There is a problem with the current on the secondary side (L6,L8) of the CTs. Current in L6, L8 is not zero (ca.0.5A offset) when current on primary side (L5, L7) is zero.
I tried changing orientation of secondary side coils (windings beginnings) but didn't help.
Can you tell me why there is an offset on the secondary side of CT?
Thank you.
Thank you.
