ltspice CD4000.LIB error messages
Discussion in 'Electronics Resources' started by celtic762, Oct 18, 2013.
  1. celtic762
    Jun 14, 2013
    I'm trying to simulate an RGB LED fader using a NE555 and CD4029 running on 9V. I've got the NE555 working in the simulation in astable mode. The problem is getting the CD4029B model to work. :confused:
    I've loaded the CD4000.lib file into the lib\sub folder
    Ive included the Spice directive .include lib\sub\cd4000.lib
    I've set value to CD4029B which is a .SUBCKT in the CD4000.lib file.
    The following warnings come up.
    WARNING: Can't resolve .param vdd1=vdd
    WARNING: Can't resolve .param speed1=speed
    WARNING: Can't resolve .param tripdt1=tripdt
    There are no .param settings for vdd, speed or tripdt set in the file. Are these values found in the manufacturer's documentation?
    Any help would be much appreciated.
    Cheers :)
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    Try set this
    SpecLine VDD=9 SPEED=1 TRIPDT=5e-9
  3. Alec_t
    Sep 17, 2013
    5,968
    1,135
    You shouldn't need to set that value. The symbol already has a value. Just right-click on the symbol and edit the Vdd value to 9V.
  4. celtic762
    Jun 14, 2013
    Thanks! :D I also had to get the pin assignments in the right order as well :rolleyes:
