LTSpice adding model for PSpice
Discussion in 'General Electronics Chat' started by bug13, May 26, 2013.
  1. bug13
    Feb 13, 2012
    1,213
    38
    I want to the this model OP07CP from here, but it doesn't seen to work, I get 7.x volt from the output instead of 5V, so how can I add an PSpice model to LTSpice?
    PS: my .asc file is attached
  2. mst3krules
    Jan 17, 2008
    You need to change the value of V3 to 5 or rotate it so the - terminal is connected to ground. As it is now, the net labeled -5V is actually at +5 volts.
  3. bug13
    Feb 13, 2012
    1,213
    38
    Arrrhhh... thanks, silly me :D
