LTI 1st order system Response Time
Discussion in 'Homework Help' started by Musab, Oct 29, 2010.
  1. Musab
    Sep 20, 2008
    25
    For a LTI first order system, the transfer function is H(s)= 1/(s+a).
    Determine wither the system response time will increase or decrease, when the pole is moved further away from the origin.
    Attempt:
    the constant a is the inverse of the settling time. so as a is increased, the system respond quicker.
    The pole of the system is jw= - a. Therefore as a is increased, the pole is moved away from the origin (assuming is +ve), and the system respond quicker.
    Is my answer correct ?
    Thanks,
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    The distance alone cannot tell us about the system responce. If the pole is a=r+jw the response time is dependant on r alone. The more negative r is the faster the system is. But if r is positive then the system is driven in instability and will never settle.
