LTC3111 - VCC shorting to Ground
Discussion in 'The Projects Forum' started by Shawn Mathew Kailath, Jun 5, 2015.
  1. Shawn Mathew Kailath
    Jun 5, 2015
    I'm using the LTC3111. I have followed the typical application on page 1 of datasheet.
    I'm operating in burst mode and no load current is drawn.
    When I power up the IC, the output Vout (pin 12 of MSOP 16) goes to ground pretty quickly.
    The only clues I have of what exactly is going on:
    1. the oscope probes are connected to FB, VCC, VIN and Vout. There is a lot of noise and spikes in the waveform.
    2. The current meter in my supply is showing 100mA-22mA-1mA depending on my voltage input.
    Please help me understand why the IC is shorting internally.
    Thank you,
  2. crutschow
    Mar 14, 2008
    13,497
    3,373
    Post a schematic of how the device is connected.
    Otherwise we are mostly guessing.
  3. Shawn Mathew Kailath
    Jun 5, 2015
    Please see attached the schematic of the circuit.
