Greetings,
I just received the LT3598 demo board from Linear Technology and I have a few questions. Below you'll find the LT3598 datasheet and also the Demo circuit quick start guide.
http://cds.linear.com/docs/Datasheet/3598fa.pdf
http://internal.linear.com/demo/dc1285A.pdf
In the Quick Start Guide, they say to connect the PWM pin to VIN. I'm wondering how I can adjust the PWM? In the schematic if I put another resistor from the CTRL pin to ground it would form a voltage divider. Thus, varying voltage. Or, would I put a resistor from the PWM pin to ground? Would this adjust the PWM? Also, what are the OPENLED, and SYNC pins for?
Thanks!
Thanks!
