LT3032 as +/- supply for opamp
Discussion in 'Electronics Resources' started by Kinnerup, Jun 29, 2010.
  1. Kinnerup
    Jun 28, 2010
    Hi
    I'm in the need of a plus minus (+/-) supply voltage for an opamp. The opamp is used in an input buffer for a ADC used for a microphone.
    I'm dealing with a battery supplied application so the trouble is how I produce a negative voltage and a positive counterpart.
    I have:
    +12 V supplied by a battery
    I need:
    +-3.2 V for an opamp
    I'm wondering if I can use the LT3032 from Linear Technology.
    And then before that produce a pseudo ground with a voltage divider (using resistors) and then an opamp. Illustrated here in Figure 7.
    Can anyone help me understanding this better?
    Or are there other suggestions?
  2. bertus
    Administrator
    Apr 5, 2008
    15,809
    2,390
    The schematic you point at is rather confusing.
    There are ground signs al over.
    I have put text where the virtual + and - will be.
    I also attached a PDF with all kinds of single supply opamp circuits.
    Bertus
  3. Kinnerup
    Jun 28, 2010
    So you suggest that the opamp configuration producing a virtual + and virtual - along with ground will supply my LT3032?
    I am also confused with the many ground signals. The signals marked with * will be a separate ground, right?
    Can someone make an outline for me. For the entire circuit I need +5V, +3.2V and -3.2 V.... My only supply is a +12 V battery.
    My thoughts are using a configuration like shown in the thread above. And then use some linear regulators to produce my exact voltages of +5 V, +3.2 V and -3.2 V...
    Does that sound ok?
  4. bertus
    Administrator
    Apr 5, 2008
    15,809
    2,390
    When you feed the opamp with 12 Volts , you will get + and - 6 Volts virtualy.
    Bertus
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
