LT SPICE, Show Command
Discussion in 'General Electronics Chat' started by BTSP, Sep 29, 2013.
  1. BTSP
    Sep 29, 2013
    15
    I am creating a netlist for LTSpice.
    When doing the simulation i want to see the parameters of the diode, dynamic resistance and such. Can i use the show command to do this? i am not sure how. i tried searching the forum, couldn't find anything.
    ***ANALOG ASS#1 CIRCUIT 1 ***
    *AC SOURCE
    vs 4 0 dc 0V ac 500mV
    *DC Biasing
    vcc 1 0 5V
    *Resistors
    Ra 2 3 10k
    R1 1 2 2K
    R2 5 0 2K
    RL 6 0 100
    *Capacitors
    Ci 4 3 16nF
    Co 5 6 16nF
    *Diode
    D1 3 5 diode1
    .model diode1 d (is=0.1pA n=1)
    show d1 [:]
    .op
    .end
    Thanks in advance
  2. upopads
    Dec 18, 2007
    42
    I'm somewhat certain that if you don't specify those advanced values, they are zero.
  3. upopads
    Dec 18, 2007
    42
    OK, no it is not. but here are all the default parameters for a diode
  4. upopads
    Dec 18, 2007
    42
    So actually uh, yes it does look like the default value for ohmic resistance is 0.
  5. BTSP
    Sep 29, 2013
    15
    perfect, that helps. Thank you
  6. crutschow
    Mar 14, 2008
    13,501
    3,375
    A diode will still have a dynamic resistance, even if the ohmic resistance is zero. It's cause by the logarithmic relation between current and the voltage forward drop. Here's a thread showing a simulation of the dynamic resistance (see Post #7). That resistance calculation is done from the simulation graphic display (see equation at top of graphic), not the netlist file.
