The MPK is a non-polarized Capacitor, it doesn't care which way the voltage goes, it will pass it.The MPK is a standard metalized poly cap. If I remember right on your schematic, the MPK cap didn't make sense where it was. Since it is in series, on a DC part of the circuit. Thought caps blocked DC?
Thank you, I didn't realize how much simpler it was until I actually began to route them.I labeled the pins as I did for several reasons; try to keep the inputs on the left and outputs on the right; supply voltage on top and ground on the bottom; and try to keep the symbol from getting overly large by keeping the pin names abbreviated yet meaningful.
It's not perfect, but it's a reasonable compromise. I'd have to have a pretty compelling reason to change it, as I'd have to re-work any LTSpice .ASC file I'd created in order to use a modified symbol; which I really don't have time to do.
You don't get that until the sim has progressed a fair way (progress is shown at the bottom of the .asc window). Did you fail to get the .raw screen even after the sim had run 100%?I don't have the second window.raw
Ok, I'll let it churn through, I do see something happening in the bottom left corner.You don't get that until the sim has progressed a fair way (progress is shown at the bottom of the .asc window). Did you fail to get the .raw screen even after the sim had run 100%?
