LT Spice parameter changing directive help
Discussion in 'Electronics Resources' started by shen, Apr 12, 2015.
  1. shen
    Apr 12, 2015
    Hi!
    I'm pretty new to LT Spice, and I would like to modify the parameters of an inverter gate. I found the following website below, which describes what should be done to be able to change certain parameters, but I have no idea how to implement it.
    http://ltwiki.org/LTspiceHelp/LTspiceHelp/A_Special_functions_.htm
    This is the directive that I tried to change the logic high level to 10 volts, but it did not work:
    .param a1 n001 n002 n003 n004 n005 n006 n007 n008 buf Vhigh=10
  2. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Right-click on the inverter symbol and in the pop-up enter 'Vhigh=10' as the Value.
  3. shen
    Apr 12, 2015
    Thanks a lot for the quick help, it works!
  4. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Good. LTS has a steep learning curve (I'm only part way up it myself) but is well worth the effort.
