Hello, I'm simulating the following circuit with LT Spice:
http://www.geocities.ws/debussy/noninvertingopamp.jpg
I'm doing an .ac analysis to calculate the input resistance of the op amp, which should be very high over the whole bandwidth (which is approximately 0-100 kHz), but I get the following Vin/Iin plot, which makes no sense:
http://www.geocities.ws/debussy/noninvertingopamp_plot.jpg
I see, by using a cursor, that the input resistance decreases from 157 GigaOhm (at 0 Hz) to 1.5 MegaOhm (at 100Khz): how is this possible? Is it possible for the input current of the op amp to so rapidly grow with frequency?
I'm puzzled because I did the same simulation on the inverting configuration and the input resistance was 1 kiloOhm over the whole bandwidth as expected.
Thanks in advance for your help.
