LT Spice - How to simulate a repetitive signal
Discussion in 'Electronics Resources' started by atferrari, Jul 16, 2007.
  1. atferrari
    Thread Starter AAC Fanatic!
    Jan 6, 2004
    2,663
    784
    Using LT Spice, how could I simulate a repetitive signal with 12 levels between +2V and -2V?
    Intention to use it as the input for a passband filter.
    Initially I tried a voltage cell with PWL output but found that it does not repeat! My fault.
    Any help out there? I will appreciate that!
  2. nanovate
    Distinguished Member
    May 7, 2007
    665
    You can try the .step command.
  3. tvd0904
    May 8, 2007
    I think you should use Vpulse instead..parameters includes PW and PER..:)
  4. atferrari
    Jan 6, 2004
    2,663
    784
    :) Problem solved using Pulse command. :)
    To use atatched file in LTSpice, eliminate .txt extension.
    Thanks for suggesting that.
