LT spice frequency analysis
Discussion in 'General Electronics Chat' started by shafee sk, May 5, 2012.
  1. shafee sk
    May 5, 2012
    In LTspice, for any AC analysis circuit, can I be able to plot 20 log (Vo / Vi) directly. If so how??
    thanks & Regards,
    shafee.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Have you looked in the Help file?
    Open LTSpice Help, click the Contents tab, and expand the "Waveform Viewer" topic.
    Waveform Arithmetic (this contains exactly what you wish to know) and User-Defined Functions are the 3rd and 4th in the topic list, but I strongly suggest that the entire section is well worth the time spent reading through it. You will save yourself a considerable amount of time by doing so. Ask me how I know this.
  3. shafee sk
    May 5, 2012
    thanks for your valuable input.
  4. shafee sk
    May 5, 2012
    ofcourse please tell me how did you come to know this??
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I've been using LTSpice for a few years now. When I first started using it, it took me about three months to discover you could display the average and RMS of a waveform interval by just ctrl+left-clicking on the signal name on the plot. Reading the HELP file would have saved me a lot of time trying to figure that (and many other things) out.
  6. Ron H
    Apr 14, 2005
    7,050
    657
    In an AC analysis, the network is first linearized at the DC operating point. This means that there will be no distortion, no matter what amplitude you apply to it. If you have a circuit such as a transistor amplifier with a small signal gain of 100, and set the AC amplitude to 1mV, the simulated output will be 100mV. If you now change the AC amplitude to 1000V, the simulated output will be 100,000V.
    What this means is that if you apply 1V AC, and then plot the output, you will get an output of 100V. 20 log(100) is 40dB, which is the gain of the circuit.
    In other words, apply 1V AC, plot Bode plot (voltage vs frequency) of the output , and you will see the gain.
