LT Spice Colpitt Oscillator
Discussion in 'Homework Help' started by Runs212, Apr 15, 2015.
  1. Runs212
    Mar 12, 2015
    55
    I designed a colpitt oscillator on LT Spice whose output is suppoed to be 1MHz. However, When i run the simulation, it outputs a DC voltage instead of a sin wave. Could you please look into to tell me if I'm doing it correctly and how to generate the sine wave. I have attached the LT SPice file for your convenience. Thanks.
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    For starters, put a real transistor in. Add the STARTUP directive to the the .TRAN command.
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    Look at the value of R1 - does it make sense that the circuit will function as expected with that value of R1?
  4. ScottWang
    Aug 23, 2012
    4,930
    777
    I haven't try this in breadboard, but through changed the values of resistor and set the bjt number, and it works.
    The same circuit is here.
  5. Runs212
    Mar 12, 2015
    55
    Thanks very much everyone. Your comments were very helpful.
