LT 1787 Current Sensing IC
Discussion in 'General Electronics Chat' started by donaldm444, Apr 8, 2013.
  1. donaldm444
    Jul 16, 2010
    23
    I am using the LT1787 current sensing IC in unidirectional mode (see attached image). In the system I'm measuring current for, there is an electromechanical relay prior to pin 7 (Vs+) that cuts off supply to the IC (in this case the current to my load is zero). Can I expect the output voltage to be zero (Vout pin), or will there be a issue because pin 7 and 2 are floating and/or the opamp not being powered?
    I have grounded Vbias as in the diagram.
    Thanks,
    Don
  2. Ron H
    Apr 14, 2005
    7,050
    657
    If your load has no other source of power except Vs, then I believe the output will be grounded through the internal 20k resistor.
