LR6/1.5V AA Battery
Discussion in 'The Projects Forum' started by Lightfire, Apr 9, 2011.
  1. Lightfire
    Oct 5, 2010
    690
    21
    I am searching about the capacity of an LR6 battery and found out that its capacity is 2700-2900 MAH. So means, 2.7-2.9 AH? am I right????:)
    Thanks!!!!!!!
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Maybe, but remember what I said about the numbers going out the window if you try to suck too much power too fast? Figure these batteries should be limited to 100ma max, and they will last a while.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    Why do they use the stupid name of LR6 when it is an ordinary AA alkaline cell?
    Why don't they call it an ordinary AA alkaline cell?
    Every battery manufacturer has a website with its datasheet.
    It can supply 2800mAh only when its load is only 25mA.
    When you load it with a lot more current then it quickly dies. At 500mA its rating is only 700mAh when its voltage has dropped to 0.8V per cell.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, "AA" is the common name, but doesn't include the chemistry.
    LR6 is the IEC name for an AA alkaline battery; basically shorthand. Most of the earlier battery types can fit in a 3- or 4-character field.
    The shorthand names were likely quite important when mainframe computer storage was at a premium back in the 60's thru the 80's.
    ANSI/NEDA names are different, too. Why that is, I have no idea. But, I digress - and this is wandering off of our OP's topic.
  6. Audioguru
    Dec 20, 2007
    9,411
    896
    I am sorry.
    My Energizer AA alkaline cells and my Duracell AA alkaline cells are marked LR6.
    I never read the label until now.
  7. Lightfire
    Oct 5, 2010
    690
    21
    Haha! Nice hit! Peace
