I was going through my circuit theory text-book and saw an example where the voltage induced in the inductor after the removal of the original source using a switch that includes larger resistors in series with the same inductor than the resistors before throwing the switch. The example demonstrated the property of inductors to effect no instantaneous change in the current flowing through it. As a result, more voltage is necessary to drive the same amount of current through larger resistances so the inductor self-induces a higher voltage across it than the source!
The example made no mention about it but something doesn't feel right to me about that, because it seems to me that the inductor would be liberating more energy than it stored, violating the law of conservation of energy. I used the equation P=V*I to calculate the power before the source was removed using the switch and after and I got a higher value for when the source is not present.
I don't understand why this must be.
Any help would be very much appreciated!
