LPF working (doubt)
Discussion in 'The Projects Forum' started by pratapkollu, Dec 29, 2010.
  1. pratapkollu
    Thread Starter Active Member
    Dec 13, 2006
    42
    Hai Members
    In the LPF diagram shown below
    Input and Output are connected by wire
    Does it filter work effectively? If so, How it works?
    I found it Maxim IC data sheet
      File size:
      31.2 KB
      32
  2. edgetrigger
    Member
    Dec 19, 2010
    133
    19
    The input is not connected to output directly as you have mentioned. Please examine the ckt carefully. I/p is passed through a RC filter here R is fixed C is actively varied(switched) by MAX280, thus making an effective RC low pass filter.
  3. pratapkollu
    Dec 13, 2006
    42
    Thnx for the reply
    I wish to remove the connection between 1 and 7,
    the top wire
    is it right decision?
  4. marshallf3
    Jul 26, 2010
    2,358
    201
  5. edgetrigger
    Member
    Dec 19, 2010
    133
    19
    You can remove C' in that loop. If you remove C then there is no filtering. If you want to do away with it you could aswell remove the IC.
  6. pratapkollu
    Dec 13, 2006
    42
    hai,
    I have the data sheets
    I cannot get your idea in sending me the link for datasheets
