LPC21xx programming in Keil
Discussion in 'Embedded Systems and Microcontrollers' started by rushabh0013, Oct 2, 2010.
  1. rushabh0013
    Jan 27, 2010
    hello friends.. it seems there is no thread related to ARM7 (LPC21xx) related programming... so i have created one... m learning ARM7 and thought others will be interested...
    I want to generate 1sec delay using timer0.
    I have written code in C in Keil for LPC2138 but it doesnt generate exact delay. If anyone find out my mistakes it will be grateful...here is the code..
    Program for Multiplexed 7Segment using Timers with ARM LPC2138
    Fosc=14.7658Mhz
    Common Cathode 7 Seg is used.
    #include <LPC213x.h>
    #define delay 1
    void wait(unsigned int a)
    unsigned int d;
    for(d=0;d<a;d++);
    VPBDIV=0x00000001; //select peripheral clock as (1/4)th of main clock
    PCONP=0x00000002; //turn on timer0
    //T0TCR=0x00000002;
    T0PR=0x000036B0; // set prescale register counter, PC will count up to this count for one clock
    T0TCR=0x00000001; // start timer0
    T0MR0=0x000003E8; //match register value
    //Delay is calculated by multiplying mr0 and (pr+1) value
    while(T0TC != T0MR0); //Wait until counter 0 gets to 1000
    T0TCR = 0x00000003; // reset timer control register to 00
    int main(void) // in ARM main should be int or it will show error
    unsigned int sw;
    IODIR1=0x00ff0000;
    while(1)
    sw=IO1PIN;
    if(sw == 0xBF000000)
    for(;;)
    IOSET1=0x003f0000;
    wait(delay);
    IOCLR1=0x003f0000;
    IOSET1=0x00060000;
    wait(delay);
    IOCLR1=0x00060000;
    IOSET1=0x005b0000;
    wait(delay);
    IOCLR1=0x005b0000;
    IOSET1=0x004f0000;
    wait(delay);
    IOCLR1=0x004f0000;
    IOSET1=0x00660000;
    wait(delay);
    IOCLR1=0x00660000;
    IOSET1=0x006d0000;
    wait(delay);
    IOCLR1=0x006d0000;
    IOSET1=0x007d0000;
    wait(delay);
    IOCLR1=0x007d0000;
    IOSET1=0x00070000;
    wait(delay);
    IOCLR1=0x00070000;
    IOSET1=0x007f0000;
    wait(delay);
    IOCLR1=0x007f0000;
    IOSET1=0x006f0000;
    wait(delay);
    IOCLR1=0x006f0000;
    thanks,
    rushabh
  2. maxpower097
    Feb 20, 2009
    795
    388
    I'm looking for info on Keil LPC uC's too. Haven't found too much on them but generic stuff. Plus all the keil examples seem to run on some sort of OS.
  3. rushabh0013
    Jan 27, 2010
    what do you want to know about LPC & Keil ARM Compiler? May be i can help...
