LPC2119 vs. 8051
Discussion in 'General Electronics Chat' started by Dritech, May 31, 2015.
  1. Dritech
    Sep 21, 2011
    756
    5
    Hi all,
    What is the main difference when comparing these two microcontrollers?
    From the datasheets I can see that the ARM is 32-bit while the 8051 is 8-bit. The 8051 is also bit accessible while the ARM is not.
    What are the other features/architecture properties that one has to consider when comparing these two microcontrollers ?
  2. DickCappels
    Aug 21, 2008
    2,746
    665
    The main difference is that the ARM controller can perform calculations and movement of data at a much higher rate than the 8051. If you understand your application you can easily determine which one is best for your application.
