LPC1788 IAP problem
Discussion in 'Embedded Systems and Microcontrollers' started by Lazar Urosevic, May 8, 2015.
  1. Lazar Urosevic
    May 8, 2015
    I'm working on LPC1788, trying to use In Application Programming, and in one project where I implemented this code:
    #define IAP_BASE1 0x00030000
    #define IAP_BASE2 0x00038000
    #define IAP_BASE3 0x00040000
    int main(void) {
    BYTE podatak1, podatak2, podatak3;
    DWORD *pointer_podatak1, *pointer_podatak2, *pointer_podatak3;
    uart0();
    NVIC_DisableIRQ(TIMER0_IRQn);
    NVIC_DisableIRQ(TIMER1_IRQn);
    NVIC_DisableIRQ(UART0_IRQn);
    podatak1 = 0x33;
    podatak2 = 0x63;
    podatak3 = 0x84;
    iap_copy_to_flash(&podatak1, IAP_BASE1, 1);
    delay_1_ms();
    iap_copy_to_flash(&podatak2, IAP_BASE2, 1);
    delay_1_ms();
    iap_copy_to_flash(&podatak3, IAP_BASE3, 1);
    delay_1_ms();
    pointer_podatak1 = (DWORD*) IAP_BASE1;
    pointer_podatak2 = (DWORD*) IAP_BASE2;
    pointer_podatak3 = (DWORD*) IAP_BASE3;
    LPC_UART0->THR = *pointer_podatak1;
    delay_1_ms();
    LPC_UART0->THR = *pointer_podatak2;
    delay_1_ms();
    LPC_UART0->THR = *pointer_podatak3;
    delay_1_ms();
    while(1)
    It works perfectly, but when I try to utilize it in my main project, I've got nothing written on flash memory locations I indicated. Here is the code in my main project to read and write from flash:
    #define OFFSET_ADDRESS 0x00030000
    #define OFFSET_VERSION 0x00038000
    #define OFFSET_SERIAL 0x00040000
    void write_to_flash (void) {
    BYTE i;
    iap_copy_to_flash(&display_address, OFFSET_ADDRESS, 1);
    delay_1_ms();
    iap_copy_to_flash(&version, OFFSET_VERSION, 1);
    delay_1_ms();
    for (i=0;i<8;i++) {
    iap_copy_to_flash(&serial_no, OFFSET_SERIAL+i, 1);
    delay_1_ms();
    void read_from_flash (void) {
    BYTE i;
    DWORD *pok_add, *pok_ver, *pok_serial_no;
    pok_add = (DWORD*)OFFSET_ADDRESS;
    display_address = *pok_add;
    delay_1_ms();
    if ((display_address > MAX_OUTDOOR_DISPLAY_ADDRESS) || (display_address < MIN_OUTDOOR_DISPLAY_ADDRESS)) display_address = UNI_ADDRESS;
    pok_ver = (DWORD*)OFFSET_VERSION;
    version = *pok_ver;
    delay_1_ms();
    if (version > MAX_FW_VERSION) version = 0;
    for (i=0;i<8;i++) {
    pok_serial_no = (DWORD*)OFFSET_SERIAL;
    serial_no = *pok_serial_no++;
    delay_1_ms();
    for (i=0;i<8;i++) if (serial_no > 9) serial_no = 0;
    display_address, version and serial_no[] are global variables which are forwarded to these two functions write_to_flash and read_from_flash. Anyone knows maybe what can cause the problem, even if the correct and working code is implemented in main project?
