Lowering V, Raising I
Discussion in 'General Electronics Chat' started by iONic, Jun 3, 2011.
  1. iONic
    Thread Starter AAC Fanatic!
    Nov 16, 2007
    1,422
    68
    The ideal scenario is to take aprox 12 - 18V DC at about 800mA and convert it to a fixed 3V with a potential current of 3A.
    Is this possible? What would you suggest is the simplest way to make this?
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  3. jegues
    Sep 13, 2010
    735
    43
    bertus seems to have linked an IC that could very well get the job done, but just for the heck of it I'll throw something out there.
    I could be completely wrong, but here it goes!:D
    Couldn't you feed your signal into a zener regulator, followed by a emitter follower?
    The zener should handle the voltage regulation, giving you a stable 3V while the emitter follower provides you with the current gain needed to pump the signal up to 3A. You might have to tweak the voltage across the zener to give ~3.7V, because if you are taking your output across the emitter terminal you will lose some voltage(~0.7V) across the BEJ.
    I'd love to hear what others (perhaps more knowledgable on the subject) have to say about this idea.
  4. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    @ jegues,
    The circuit you propose will have an input current equal to the output current.
    The voltage difference X output current will be dissipated as heat.
    The efficiency is very low.
    Bertus
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    12v @ 800mA is 9.6 Watts; 3V @ 3A is 9 Watts, so you would need a DC-DC converter that is 93.75% efficient or better. That is possible, but it's not exactly simple.
    You will need to do a good bit of research on SMPS's (switch mode power supplies).
    I've attached a couple of PDFs that will give you a brief intro.
    You can do a lot of reading on http://www.smps.us
  6. iONic
    Nov 16, 2007
    1,422
    68
    Thanks guys. This should get me started...with a great many more questions, but I will try to sort it out somewhat myself.
