Hi to everyone
i am an electrician from Goa India where my input voltage is 237-256volt rms and i am planning to buy a LG LED LCD tv which operates from 100-240volt with 78watt and a STB of DTH is also of the same rating but is only 15 watt now i have a stabilizer which brings down the above voltage to 216-238 volt.
Now my question to all is that if this two load are combined together it will be around 95 watt and if i connect a 100 watt fan regulator in series with this load and step down the voltage to around 150volt will the STB and TV work and secondly will this equipment be safe for minor spikes as both the equipments are working on 24 volt.
do let me know about this.
thanks.
nelson
thanks.
nelson
