Low Voltage Zener
Discussion in 'General Electronics Chat' started by Robert.Adams, Sep 6, 2011.
  1. Robert.Adams
    Thread Starter Active Member
    Feb 16, 2010
    112
    5
    Is there a device that could act something like a 200-300mV zener? I have a design that has a node that is voltage controlled by a transistor to be 5V + Vbe and I need to bump it up by about the amount mentioned.
    If I try to cascade Vbe's I can accidentally turn on a different part of the circuit so I'm looking for something in the low range I mentioned above.
    Thanks!
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Nope, but a germanium diode drops approximately 0.3V.
    Usually voltage dividers are used.
  3. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
  4. Robert.Adams
    Feb 16, 2010
    112
    5
    Ah, I shall look into those ideas.
    A voltage divider isn't plausible since the node is in the middle of a discrete current source/sink configuration. The current is PWM controlled and a clamp makes sure the voltage does not exceed a certain value.
