Low voltage submersible pump safety
Discussion in 'General Electronics Chat' started by Ringoko, Feb 13, 2012.
  1. Ringoko
    Feb 13, 2012
    I've bought a pet fountain with a submersible pump which operates on a 12 volt adapter. Soon I have second thought since I know nothing about electricity or safety of electrical appliances. Would anyone please advise:
    1. In case there's any power leakage into the water, is my cat safe when she drinks it? (I read that human death could even occur for 50 volt electric shock. Is 12 volt safe enough for my 10 pound cat?) :confused:
    2. Instruction manual says water level should be above the pump all the time. In case water level is below the pump, is there any hazard? :confused:
    3. Instruction manual also says the pump should "always run under direct supervision". That scares me. :eek: Of course that's not practical and it is expected to be unattended very often. Is there any possible hazard? :confused:
    4. I read from the web that submersible pump should have a grounded plug to be safe. The adapter for the pump has 3 prongs. Does it mean it is grounded? :confused:
    Many thanks! :D
  2. mcgyvr
    Oct 15, 2009
    4,789
    974
    If the pump as 3 prongs (and it must) then it is safely grounded. Don't worry..
    And its not the 12V thats the problem really..its the other side of the transformer with the line voltage on it that could get wet in the event of a leakage.
    Ringoko likes this.
  3. luvv
    Member
    May 26, 2011
    186
    31
    Make a drip loop in the wire and tie it off there, it prevents water from traveling all the way back to power adapter.
    http://freshaquarium.about.com/od/equipmentquestions/f/driploop.htm
    It's a good idea to do this w/ any hoses or wires that exit the aquarium it can prevent water from reverse siphoning water into air pumps ect.
    Other then that if the pump looks sketchy use a lil pure silicon caulk around where the pump and wire intersect.
    -luvv-
    Ringoko likes this.
  4. BSomer
    Member
    Dec 28, 2011
    433
    106
    The reason you want to keep the water level above the pump may be two fold.
    1. To prevent the pump from sucking in air and causing it to lock up and stop working.
    2. Possibly may be needed to help cool the pump durring operation.
    As the others have stated though, you should have no problems with your pump since it is grounded through the third prong on the plug.
    Brian
