First, one detail. As drawn the LED will never light. The LED needs to be connected to +12V so that the comparator lights it when it pulls the output to ground. There is no output when the comparator goes "high". So the present logic will turn the LED off when the input voltage becomes high enough. If you want to change that, reverse the inputs at the comparator so that the output goes low - lighting the LED - when the voltage on the inverting input is high enough.
Your input signal may not be what you though it was. The 2.2V at the peak detector proves that. How did you determine the voltages you initially posted, probably a DMM set to measure DC voltage? Do you have any information on your receiver that might help sort that out?
In the meanwhile you can make sure the rest of your system is working by applying known voltages as your signal. Maybe you have a solar cell lying around? You could test that the LED comes on when the solar cell voltage reaches the right level, about 12v x 10/110 = 1.1V reference + 0.6V diode drop = 1.7V.
