I'm trying to build a battery pack to power a small device. It needs to be able to provide around 11 amps at .7v into what is more or less a dead short (it's powering a small heating element). I plan to use either a pack of 6 NiMH AA cells or one or two lithium cells. Figure 6-9 volts input range. Runtime doesn't need to be exceptionally high but I'd like to get at least 30-45 minutes of continuous use at a minimum. I started looking into how to do this and I realized I have no real clue where to start.
I know I need a buck circuit. It needs to be regulated to keep the current between 10 and 12 amps. I've no clue how to go about creating either of those or what parts I need. I'm hoping someone here might be able to help me out a bit.
edit: if I could buy a premade module that will work or can be made to work, I would much prefer that over having to build the entire circuit from scratch.
edit 2: Could I use something like this?
