low voltage cutout
Discussion in 'General Electronics Chat' started by freebz, Sep 16, 2008.
  1. freebz
    Sep 16, 2008
    hi
    i'm looking to install a low voltage cutout to protect a 11.1v li poly battery in my RC car i believe the minimum safe voltage is 8.6v so if it cut out at 9v would be good ,the car draws 11A at full load. as i have limited knowledge in electronics an easy curcuit would be favorable. i was thinking of a transistor, zener diode system rather than using a standard relay and a zener diode because of the current needed to operate the relay.
    any help would be much appreciated
    thanks
    dave
  2. mik3
    Feb 4, 2008
    4,846
    63
    Look for comparator circuits in google with op-amps.
    Here is one i found
    http://home.cogeco.ca/~rpaisley4/Comparators.html
    There are thousands.
