I have checked it against the pin out you sent it looks correct. Did you see the PCB layout
Sorry PCB layout is looking at the component sideDon't you ever breadboard circuits before committing to a PCB? I always do.
I cant even tell if I am looking at the top or bottom of the PCB.
This makes no sense.Mike I did the following tests.
Adjusting the trim
Voltage on the junction of the 100K and the pre-set Max 3.4V Min 2.45V
Voltage on the junction 33K and Trim
Max 2.51 Min 1.87
Voltage on the Pin 1 of The TL431 remained on 2.51 regardless of how I turned the trim.
I have just checked again.This makes no sense. You do have all three terminals of the pot hooked up? Wiper goes to REF input of TL431. Top goes to the 100K, Bot goes to 26K. Hysteresis resistor goes to wiper/REF?
The thing that needs to move when you adjust the pot is the Wiper/REF voltage. The Top and Bot voltage will remains constant.
Does that mean that the TL431 was in backwards? If so, it may be compromised....
I turned the TL431 around and got exactly the same results.
I removed the TL431 from the circuit, the test light did not come on regardless of moving the trim.
With the TL431 removed, the PFET's gate is tied to its own source, so is turned off, so the light would be off.
I remember you saying that the initially, the light came on even at low voltages. That would be consistent with having the TL431 anode and cathode swapped. I'm guessing that you have a damaged TL431
this is all very new to me PFETS I mean. I hope I have understood the Datasheet. VGS +- 20VWhat is the threshold voltage of the PFET?
I had company here all day, today...I have got to the point now where my knowledge ends. (for now) I have yje circuit working right up to the mosfet. There is always 2 volts on the gate until the voltage drops to 10.6 volts. Then the gate goes to 9 volts. However during this time the Light switched by the mosfet stays on.
I have connected a 23 watt load between the source and negative
by Duane Benson
by Aaron Carman
by Robert Keim
by Jake Hertz
