low voltage 1ma Constant current circuit
Discussion in 'The Projects Forum' started by Karenzee, Jul 2, 2016.
  1. Karenzee
    Mar 6, 2015
    15
    i searched the forum for constant current circuits but didn't extactly found what i needed.
    the circuit should operate as low as 1v (max 5v) and the output current 1ma.
    Precision is important.
    Current regulator diodes are a possibility (are the j505 recommended?) but a cheaper alternative would be great.
    Thanks!
  2. Dodgydave
    Jun 22, 2012
    5,138
    767
    What about a J113 fet circuit?
  3. sailorjoe
    Member
    Jun 4, 2013
    361
    63
  4. crutschow
    Mar 14, 2008
    13,472
    3,361
    What is your supply voltage?
    Does the load need to be grounded?
  5. RichardO
    May 4, 2013
    1,334
    429
    How precise does the current have to be?
    The 1 volt minimum requirement is a tough one. The J505 needs as much as 2.1 volts to regulate. :(
    Even the amazing LM10 op-amp/reference needs about 1.2 volts to operate... And the LM10 is little pricey at $2 to $3 each. :(
  6. Bernard
    Aug 7, 2008
    4,232
    414
    LM334, adjustable current source, max. out - 10 mA, input V - 2-20 V.
  7. Karenzee
    Mar 6, 2015
    15
    Thank you for all the suggestions so far!
    I thought that the j505 worked as low as 1v (need to check the datasheet again)
    isn't there current regulator diodes fit for this? (the gain of space is a big plus)
    supply voltage 3v to 6v
    precision is important but 1ma to 1.15ma is ok.
    note that i test soil and water so the output/electrodes are submerged/buried.
  8. dannyf
    Sep 13, 2015
    2,196
    417
    jfets would be a good choice here. Setting precise current output is tough with those guys, however.
  9. Bordodynov
    May 20, 2015
    670
    194
    See
    Karenzee likes this.
  10. Karenzee
    Mar 6, 2015
    15
    Bordodynov,
    This looks good, thank you! (isn't there an alternative for the 2sd2704k?)
    I'll probably try this and also go for 2.5 - 3v with j505 (cheaper than the LM10).
  11. Bordodynov
    May 20, 2015
    670
    194
    alternative for the 2sd2704k (hfe=820-2700) is transistor with high gain (hfe>400). for example BC547C.
    alternative BCV61C - DMMT5551, BCV62C -DMMT5401
