Low temperature measurement
Discussion in 'Embedded Systems and Microcontrollers' started by gsharman100, Jun 17, 2014.
  1. gsharman100
    Jun 4, 2014
    Hi
    I want to design a simple circuit that will measure temp down to -20c
    using a k type thermocouple . When the temp falls below -20c turn on a +24 volt 100 watt heating element I am thinking of using the AD8495
    Any suggestion please ?
    e mail gsharman100@hotmail.com
  2. shteii01
    Feb 19, 2010
    3,519
    515
    This could be purely analog system, without the use of microcontroller.
    If I am reading datasheet right:
    At -20 °C the output voltage of AD8495 will be -0.1 V. You apply this to inverting amplifier, so -0.1 V goes in, 1 or 1.5 or 10 or 15 or whatever volts comes out. This is then goes to the transistor that is used as a switch.
    If you do it the way I described above, I am kinda concerned about the current. The 24 V 100 W load will have I=100/24=4.166 A current through it, lets play it safe and make it 4.2 A. Generally, at least in BJT transistors, you will want current going to the Base of BJT to be 1/10 of the current going into the Collector of BJT, so 4.2/10=0.42 A=420 mA. I don't know off hand of op amp chips that can source 420 mA.
    Let us wait for more experience and wiser head to chime in.
  3. THE_RB
    Feb 11, 2008
    5,435
    1,305
    For a 24v DC 4A load I would use a NFET.
    Something like a 60v 50A N-channel FET in TO-220 package and "logic level compatible" are very commonly available now and can be driven direct from the opamp or comparator output pin. That solves the base current problem. :)
  4. shteii01
    Feb 19, 2010
    3,519
    515
    See what I mean about more experience and wiser!
  5. mcgyvr
    Oct 15, 2009
    4,798
    979
    any why a thermocouple?
    There are easier/less complicated ways of getting temps..
  6. MrChips
    Oct 2, 2009
    12,657
    3,461
  7. shteii01
    Feb 19, 2010
    3,519
    515
  8. ErnieM
    Apr 24, 2011
    7,447
    1,628
    You think not?
    Then go build me one accurate to +/-3 degrees F.
    No cheating, you can't copy one. You have to start from basic raw materials.
    Ready... set... GO !!!
