Things to consider when configuring LEDs in a series or parallel circuit.
I thought Christmas lights are supposed to flicker.Heh, my bad.
Adjuster: I have several sets of AC driven Christmas lights that don't flicker. You can see some flicker if you shake them fast, so as the doctor said; "don't do that!"
What do we have here, a comedian????I thought Christmas lights are supposed to flicker.
Perhaps, "Twinkle" would be more apropos!What do we have here, a comedian????
Those three parallel strings of series LEDs should not be wired like that. Furthermore, the way that's wired you're not guaranteeing constant current though each LED.@CDRIVE: I don't think the resistors are needed for each LED in parallel configuration because it's a constant current source, not a voltage source. Also each chain is fused in case something goes wrong, but under normal operation it should work correctly.
