Hey guys,
I'm planning on making an LED display that will be outside, so I expect temperature ranges from -40 to +40 Celsius.
I'm going to drive the LEDs with a lm317 configured as a constant current source which should be ok at that temperature. What I'm wondering is how reliable LEDs are at that temperature. From what I've read, most should be fine until -40°C, but I don't want to have the replace the LEDs. Does anyone know if there are there special types of LEDs that are better suited for low temperatures?
Also does anyone know if there are resistors and capacitors that are better suited for low temperatures (the resistor and capacitor used in the lm317 circuit to set the current) or should I just use normal ones.
Note: The electronics will be in IP65 housing so water should not be a problem, but humidity might be.
Thanks.
Thanks.
