What would you comment on this graph of load current in low side MOSFET ?
H Thread Starter hackers99 Joined Nov 18, 2009 36 Dec 1, 2009 #1 What would you comment on this graph of load current in low side MOSFET ? Attachments F0012TEK.BMP 76.1 KB Views: 25
beenthere Joined Apr 20, 2004 15,819 Dec 1, 2009 #2 Current peaks when the FET is turned on, and falls when it it turned off. That may be an inductive spike.
mik3 Joined Feb 4, 2008 4,843 Dec 1, 2009 #3 I think the graph is the voltage and not the current. If you post the circuit where the MOSFET is used the explanation will be more accurate.
