Hello to all. How can I change a relay resistance to 11 ohms The circuit is 11.5 volts
B Thread Starter bourne Joined Mar 24, 2011 1 Apr 8, 2011 #1 Hello to all. How can I change a relay resistance to 11 ohms The circuit is 11.5 volts
Wendy Joined Mar 24, 2008 23,429 Apr 8, 2011 #3 You could put a parallel resistor next to the coil. I agree with JDT though, why? This would pull around 1A. Usually you are wanting to get the resistance up, not down, to reduce the current flow.
