Hello, I am trying to make a low power Tesla coil. The problem is I am not aloud to use mains power in any of my projects due to my paranoid parents, so I am currently stuck with using one of those portable fly zapper circuits that puts out around 1600V DC. I am not sure what the current draw is but it is powered by 2 AA battery's so I am guessing that is way under powered for a Tesla coil, even a small one.
I have tried making up a jar capacitor bank and putting them in parralel with the zapper (the zapper has a built in capacitor) and then putting a small spark gap in series with the primary coil of my Tesla coil. As you might have guessed there is NO break out from the topload, but when I put a grounded object next to the top-load I get an arc of about an inch from the top-load to the grounded objects. These arcs are more of a light pinkish colour rather than a bright blue colour. I have tried using an ignition coil to drive it set up in a conventional Tesla coil tank circuit using the bug zapper pulsed through the ignition coil to power it set up but I don't even get an arc when using grounded objects using that. how ever when i just hook up the ignition coil to my zapper it outputs a blue arc of around half an inch.
So basically my question is will the fact there is limited current available from the AA battery's in the bug zapper effect the operation of the Tesla coil?
Thanks! (sorry if my spelling and grammar is off as I am tired).
